hello I need help to clone an ECU
The car seat altea 1.6 tdi ecu 03L906023GG
the two ECUs have the same reference
I read the 2 eproms
i need to transfer immo date from eprom car to eprom donor
If anyone can help, I appreciate it
I read the 2 eproms
Here is eeprom for donor ecu with your orig immo.
Try and report
Rgs H2Deetoo
lupu_sandu (10th March, 2022)
Help me to clone too PRC2.1
Try this eeprom for donor ecu with your immo!
Thanks. I'll check the file and give you an answer.
Checked. The error that the block was locked disappeared, but there was an error that the block was encoded incorrectly. Odysseus was updated, so nothing has changed. The error that was on the old computer remained on the new one.
I only did immo transfer so that part seems to work fine.
Post your full DTC error here maybe someone else can help you with that.
Control unit incorrectly coded:this is after immo transfer
Replaced the pump and repaired the injectors. The car won't start and there is only one error. High fuel pressure, and immediately low pressure. This is just one mistake, I don't remember the code. Replacing the computer did not help, the car went to another master.
i can do up internal flash and eprom
