Results 1 to 9 of 9
    GB
    Default clone Simos Pcr2.1
    hello I need help to clone an ECU
    The car seat altea 1.6 tdi ecu 03L906023GG
    the two ECUs have the same reference
    I read the 2 eproms
    i need to transfer immo date from eprom car to eprom donor
    If anyone can help, I appreciate it
    Oct 2014
    Netherlands
    Here is eeprom for donor ecu with your orig immo.
    Try and report
    Rgs H2Deetoo
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    lupu_sandu (10th March, 2022)
    Feb 2019
    Ukraine, Rivne
    Default PRC2.1
    Help me to clone too PRC2.1
    Oct 2014
    Netherlands
    Try this eeprom for donor ecu with your immo!
  6. #5
    Feb 2019
    Ukraine, Rivne
    Thanks. I'll check the file and give you an answer.
  7. #6
    Feb 2019
    Ukraine, Rivne
    Checked. The error that the block was locked disappeared, but there was an error that the block was encoded incorrectly. Odysseus was updated, so nothing has changed. The error that was on the old computer remained on the new one.
  8. #7
    Oct 2014
    Netherlands
    I only did immo transfer so that part seems to work fine.
    Post your full DTC error here maybe someone else can help you with that.
  9. #8
    Feb 2019
    Ukraine, Rivne
    Control unit incorrectly coded:this is after immo transfer
    Replaced the pump and repaired the injectors. The car won't start and there is only one error. High fuel pressure, and immediately low pressure. This is just one mistake, I don't remember the code. Replacing the computer did not help, the car went to another master.
  10. #9
    alonedark's Avatar
    Feb 2017
    i can do up internal flash and eprom
