Results 1 to 5 of 5
    Mar 2022
    poland
    Default e91 325d edc16c35 egr off
    Hello. Can someone show me where i can find the egr map in winols? I already delete it from engine but i have to do it in ecu. The next question is:if i change the value of egr in map, do i have to change maf values?
    UK
    Hey,
    There's two EGR control maps at CC5D2 and CC638, both need to be zeroed. There's also a few DTC's that need to be disabled further down in the file. No need to correct an MAF related maps.
    Attached is a EGR off file for you. Checksum is also corrected.
    No password.
    J.
    Thanks and rep appreciated.
  3. The Following User Says Thank You to johnnybeast For This Useful Post:
    wolt910 (10th March, 2022)
    Mar 2022
    poland
    Thank you a lot. Everything works good. How do you find that? Can you explain me? I want to make things by myself in future
    UK
    For EGR/DPF removals, it takes a lot of research, learning and time.
    Start with trying to get damos/map packs for the ECU you're working on, then it's all about learning what to do and what to look for to make a good file.
    J.
    Mar 2022
    poland
    Ok, i will look for it. Thanks again and have a great weekend
