I think are you silly
Because? tell me the problem or your opinion?
this setup will need logging and tuning accordingly ,that turbo is only good for about 1.8bar boost or 210-215hp on a good day upload youre file i may be able to help get it to run nicer on the arl injectors but it will need a full custom map
try this and report
davidelbosque (17th March, 2022)
Thanks so much chrissysnait for the information the Next week im finish the turbo installation, and in this moment i need help from profesional to do me a good tune file, you have my thanks bro!
Yes sure you can use 1.8 with 2.5 sensor
Dont worry im get a map sensor 3bar from Arl
andchrissysnaithy change map sensor linearion in her mod files or only use 1.4bar in her mod?????? you can get in low a good pressure no????
3bar sensor without best refrigeration and 2052 good performance
1.8+1 atm pressure you get 3.1,3,2 peaks like they did the mod I still don't understand
required 3.bar sensor. and intercooler. the little one can't handle the pressure and the loose on the joints is useless. need femic or similar
you're right I'm going to need a bigger front intercooler, tomorrow I'm going to look for a second hand one and buy the 3 bar map sensor, thanks guys the Next week im im upload my stock original file yo dow me a perfect stage , thanks so much
