Results 1 to 10 of 10
    Dec 2021
    Bosnia and Herzegovina
    Default CAS 2 Flash and Eeprom check
    Can someone please check the flash and eeprom and tell me if they are good.
    Car: BMW E60 2004 530D
    CAS2 (E6X) 61.35 - 6 943 857
    Thanks in advance.
    Alexandru82's Avatar
    Feb 2021
    VIEN
    Hi,your eeprom CAS is bad,please send eeprom ECU and flash to generate another eeprom CAS and sync,after send you back new eeprom CAS for you car and immo! Please send picture with CAS and serial number/
    Frist REP+THANKS
  3. The Following User Says Thank You to Alexandru82 For This Useful Post:
    mire922 (19th March, 2022)
    Feb 2019
    What he said. Your eeprom is corrupt, VIN and mileage
  5. The Following User Says Thank You to looneyman For This Useful Post:
  6. #4
    Feb 2021
    VIEN
    Default RE
    It's not that he doesn't have a VIN, he's corrupt in all respects, 90% is missing everything
    Dec 2021
    My bad i uploaded the wrong EEPROM without checking it first sorry...
    Here is the EEPROM :
  8. #6
    Feb 2021
    VIEN
    The eeprom CAS is ok,what problem do you actually have with the car or what error does it give you on the diagnosis?I'm also waiting for eeprom from the ecu unit if you can and I can help you fix them if there's a problem there!
  9. #7
    Dec 2021
    I was making a key on a E60 BMW and the CAS2 got messed up and the car wouldnt start so we tried everything i have send the eeprom to few guys and everyone told me the eeprom is good but the flash might be bad and thats why the car wont start... so i bought a new cas module and wrote this eeprom on it and the car started without any problems.
    After inspecting this "bad" module i found 2 pins soldered together by accdient i cleared everything on the board and read it again and im wondering if everything is good now and will i be able to reuse the module in the future.
  10. #8
    Feb 2021
    VIEN
    Attach the dump eeprom from the engine ecu to see if it is synchronized with CAS
  11. #9
    Dec 2021
    I dont have the car here anymore...
  12. #10
    Feb 2021
    VIEN
    And let us toil in vain to help you...
