Results 1 to 11 of 11
    Mar 2020
    Default cas 3 problem? please help check the file
    hello guys
    i have bmw e90 2007
    have problem dtc A114 cas: LIN FAULT, ESL STEERING and on dme i have dtc 2F4A dme: INTERFACE EWS-DME
    i checked the wire harnes and was good, changed elv also tried with emulator too, but still i have this fault code.
    I THINK the problem is eeprom or flash, can somebody check the file please?
    also i have another cas 3 but on original cas is PROCESSOR IS 0L01Y AND THE DONOR CAS IS 0M23S , if the original file is good, can i write eeprom and flash on the donor (with different processor?)
    thank you guys
    Feb 2016
    Malawi
    Your cas dump is corrupt or has been manipulated, totally messed up. . .
    kiszka's Avatar
    Quote Originally Posted by Muhammad Kassam View Post
    you are very wrong, this is the CAS2 to CAS3 end
    Mar 2020
    its cas3 BLACK BOX but i don't know if the dump is good or not
    Feb 2019
    Your eeprom is good.
    Did you reset the ELV counter?
    What is the story behind this car?
    Feb 2016
    Malawi
    You are right, I was looking at it as CAS3+
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by silver1 View Post
    thank you guys
    you can clone from 0l01y to 0m23s i have done it before.works!
    If i Helped you,use thanks and rep button to thank me back
    Mar 2020
    any procedure to clone? or just write originsl flash and eeprom from 0L01Y to 0M23S?
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    I think sizes are not the same,so no
    Sep 2020
    Quote Originally Posted by Stelaras26 View Post
    I think sizes are the same,so just read,backup,write
    i think u are so far from reality , because eeprom from 0L01Y will never work with flash from 0L15Y and vise verse
    so i dont understand why u put people into mistakes and simply take their time in ass
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by bmwspec View Post
    Bro,Speak with more respect or dont speak at all
    Mistakes are human, and everyone can search for themselves to see if its good or bad solution
