Hello, I have such a problem. He got a Citroen C5, someone fumbled with it, and smashed the ECU. Apparently the ECU has been replaced and the imo has been added, but there is a problem with the error p0283 turbo sensor. At the sensor output, there should be a 5V ground and signal. Unfortunately, I have 6V on the signal. It is not the fault of the cables, I have seen the whole ECU and I do not know what should be correct, maybe someone after Vin would be able to come?
