Results 1 to 2 of 2
    May 2009
    Sydney, Australia
    Default Opel Astra G mismatched key reader
    Hi guys i have a bit of an issue with an astra-g it had a faulty ecu so i bought the whole kit from the wreckers but it seems to be the incorrect key and key reader, i have obtained the security code for the new ecu and tried coding the key with T300, key programming was successful but still no start.
    What are my options with this problem? any info relating to this would be great as these astras are a real problem here in australia.
    Cheers
    obdmaster's Avatar
    Never never land
    Question
    Quote Originally Posted by MrMike View Post
    Cheers
    Your system is im*obiliser 2 m8, on im*obiliser 2 you cant use a used chip must be new, try programming again with a new id:40 transponder m8. If you already done this what are fault codes in ecu and immobiliser?
