Results 1 to 10 of 10
Threaded View
    Sep 2021
    Default New Start of Injection & Durations - EDC15 200bhp
    Tried to aim for 6 Degrees ATDC for EOI seems to run a lot better not sure I should add anymore without a turbo upgrade
    I think someone told me around 70IQ + 40 Duration or something like that... I've just tried to keep durations calibrated correctly to 70 IQ in excel and adjusted SOI for the extra IQ..
    I understand people try to keep them calibrated but can you not increase the values even more for 70IQ or do you need to go up to 80 IQ and stay calibrated? not sure where durations max out on these PD130/150 injectors...
    Would be greatful for any feedback at all. 50
    Maps changed:
    • Start of Injection (0*C - 90*C)
    • Duration 00
    • Duration 01
    • Duration 02
    • Duration 03
    • Duration 04
    • Boost limiter
    • IQ by MAP limiter
    • Smoke limiter
    • SVBL
    • SVRL - 4,000rpm
    • Torque Limiter
    • Drivers Wish
    • EGR OFF
    • Launch
    • Boost Target
    • N75
    PD130 ASZ stock turbo
    Stock injectors
    Full straight pipe
    EGR / ASV deleted
    EGR Cooler deleted
    HKS cone
    PD150 headbolts
    FMIC
    Solid flywheel & new clutch
    upgraded engine mounts
    new timing belt kit / pump
    new oil pump
