Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: JTAG and DM500S
    Oct 2008
    Default JTAG and DM500S
    Have read a lot of posts about Jtag and dreambox in here - great help!
    I have used the windows program and after a few try I got connection to the box and was able to write a new boot to my DM500. When I used Dreamup to flash a new image to the box it says boxtype 56xx and not 500.
    What to do now? Just continue and flash a new image or Jtag from beginning?
    Kelly_DK
    Aug 2008
    Quote Originally Posted by Kelly_DK View Post
    Kelly_DK
    Just looks like you flashed the wrong bootloader file, was it from this site?
    Try another from the D/L section and try another Dreamup from here or use the popular search engine.
    jbvid
    Oct 2008
    Yes it was a file from this site.
    Where to find the right bootloader file?
    Kelly_DK
    Oct 2008
    Hmm I have read something about that I can just change the blimg file, that is in the folder for jtagwin5xxx...anyone who knows where to find the right blimg file for DM500 clone?
    Thanks for all your help so far
    Aug 2008
    Depending on your Tuner you could change 2 of the four Alps or Phillips files to blimg in (boot.zip, boot(2).zip) and try them, unless anyone knows the secret of these illusive blimg files.
    jbvid
    Oct 2008
    ahh so the secret is just to rename the dm500-alps-boot.bin to blimg and use the windows program to transfer the bootloader to the box?
    Kelly_DK
    Aug 2008
    Kelly_DK
    I found this in my collection, it mentions success with Alps tuner on a db500 in a readme file so is worth a try, as i'm not too sure about just renaming the Alps bin file to a blimg, so try this first unless you feel brave.
    jbvid
    Oct 2008
    Hi jbvid
    This is the same folder/file that I have used for my DM500 clone.
    Dreamup just shows that the model type is a DM56xx, so it seems that the blimg file is not the right one...
    I was hoping that someone had the right blimg file for the program...
    Maybe there is stille someone out there that knows how to solve this problem.
    But thanks again for trying!
    Kelly_DK
    Aug 2008
    Hi jbvid
    Kelly_DK
    Try this one
    jbvid
    May 2008
    22222222222222222222222222222222
    I will try this also
    Mar 2009
    Default Almost there
    I have the same problem . I made everything as the instructions but my dm500 says dm56xx instead and although the RS232 is working I think there is not much to do from there . I tried everything. Do I have to jtag again? And has anyone found a blimg that works with dm500 clones? please help !!! It's the second dm500 that goes boommmm !!
  13. #13
    Hello!
    I have a problem with a dreambox 500 clone that is not related to pc by
    the jtag and test out a message I want to remind contection error that LAMPS displayt not the green light.
    dreamboxi there any way that relates to the pc or dreamboxi has finally died.
    Forgive me for my bad English
  14. #14
    Mar 2009
    @Kelly_DK
    I have the same problem with my 500s did you finally found a solution?
  15. #15
    Apr 2009
    Default how to jtag dm500s
    Sal.ma all overdrive for some time with .. dm500s fail to find file blimng correctly. We do jtag cable I followed the procedures described on several forums ... but normal flow procedure fail to bring to life. can not do something corect.folosesc jtag my dm500 and appears:
    Flash info. : INTEL Unknown
    [dm500] reading CA:ca 00 01 06 20 83 69 00 00 00 00 00 00 06 04 ff
    [CA] 4th mac addr byte is not redunderant, fixing it
    [CA] 5th mac addr byte is not redunderant, fixing it
    [CA] 6th mac addr byte is not redunderant, fixing it
    Readed Config Area
    Configuration Area
    Mac Address: 00:00:00:20:83:69
    Redunderant Mac Address: 20:83:69
    Tuner Type alps
    Mac Address Change Requested
    INTEL flasul is TE28F640. Do not you proceed corrections? how to proceed? thank for help me.sorry English if I spell correctly
