Results 1 to 8 of 8
    Default Mercedes A Classe Airbag 0 285 001 222 crash
    Can somebody help me to clear this airbag ?
    Is from Mercede A classe 2002, Bosch 0 285 001 222 with HC11K4.
    best regards
    key
    Senior Member drivergabriel's Avatar
    BUCURESTI
    try these one, and dont forgot to post result!!!
    Where are you from???????????? Beacouse i cant see that in your profile... maybe you will compleet-it!
    Hi , how did you read it ?
    I 'm trying to read this ecu with upa-usb but I don't succeed !
    I want read Hc11k4 80 QFp. I removed mcu from board plugged from upa schema and I have the bug for high power modA 3.16V How does it read?
    Mar 2009
    Quote Originally Posted by paczus View Post
    HI .
    TRY TO READ ON BOARD LIKE PHOTO CONNECTION
    REGARDS
  6. The Following User Says Thank You to HONDA C For This Useful Post:
    capi (16th April, 2018)
    hello my friends . i too cannot read this micro . i am wiring to micro same as HONDA C post but getting " Vdd/Vcc Out of range " . does anyone have a solution to read these ?
    regards
    sparkle
    please add rep & thanks if my post was helpful
    DK Veteran zeljolaki's Avatar
    In my garage
    I read a few days ago, lift pins 75,76,77,78 and 79, set in the quartz 4Mhz and must work.
    Good luck!
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Thanks for "Mavi" user:
    Problem solve
    80pin 1E62H
    HC11K4
    With UPA raise
    P6 MODB
    P7 RESET
    Tested 100%
    regards
    Mavi
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
