Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    Default Tacho Universal "RESET" problem
    I just bought from www.obdfocus.com a Tacho Universal which was supposed to be a V2009 but says EDITION 2007 - TACHO 2008 - with update from January 2008.
    I was trying to update it so followed the instructions with the "0" Update function.
    Now when I select "OK" Continue it shows "RESET" on the display.
    I tried the #83 Serial Comunication cable and didn't work to connet. As well, and not being sure the cable is a DB9: 5-5 2-3 3-2 I used a crossed RS cable from a Dreambox and still cannot connect to any Dump.
    I have the following forders with files: TachoDumpSetup; tacho 100%_working; Unlock; tacho 2008 dump sahin45; TACHO200801UpdateKit
    Can I solve it? Can someone help me with instructions?
    z786's Avatar
    10 Steps Ahead of You
    you shud NEVA update using 0,infact you shud neva update it at all its a clone!, im afraid youve f*cked it, u need to reprogram or change ic111 & ic112 on circuit board, and there is no such thing as version 2009
    sorry 2burst your bubble
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    electromech's Avatar
    Behind a large rock
    Good day you will need this
    "u need to reprogram or change ic111 & ic112"
    Ok, I got that, I was searching the Internet and realized that when I read efichip.com.
    So can I reprogram it? How can I connect it to the PC? Is the crossed RS232 Cable from the Dreambox useful? Is the included #83 cable viable? What software to use? I tried "TachoDumpSetup" and cannot syncronize it
    So can I force a new firmware?
    Last edited by jacques71; 20th February, 2010 at 12:41 AM. Reason: Sama image as before
    Behind a large rock
    Hello you need to remove chips from board and program with a programmer I am not aware of a method without removal of chips
    Quote Originally Posted by electromech View Post
    Thank you that is just what I needed
    yasser's Avatar
    Bulgaria, Varna
    Thank you.
    Behind a large rock
    Come on guys they gona nail us please use the thanks button ...........and by the way it was my pleasure
    DK Veteran m3m5's Avatar
    I've got the same machine.
    Never you can update by software. You have to buy an Upgrade kit.
    Top Poster + VictorBazan's Avatar
    Chile
    You need reprogram IC111 and IC112 Amic 29F040, try GQ4X (mcumall) or similar programmer.
    Behind a large rock
    Quote Originally Posted by m3m5 View Post
    Good day this machine hasnt got a resync problem he has tried to update a clone and therefore only need to reprogram chips
  13. #13
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    yes but sometimes you may update them or in my case i chaged them for updated ones and then had other problems so i bought my kit from ecutools.com and then you have everything to do the job and it dont cost much
  14. #14
    Thank you electromech
  15. #15
    florinyes's Avatar
    London Middlesex
    May be a bit late, but may help someone..
    Cable that comes with tacho universal is ok to connect to pc. Scroll down on menu select sync and then open tacho dump...
    Ta
