im trying to find out how to get activation code from winhex
try this work
ebrar46 (6th August, 2018), RisingMikey (29th April, 2025)
thanks ...
i'm trying to find the activation code for op-com too, can't find the 8-3 serial number or the 8-8, help please
Use this version:
RapidShare: 1-CLICK Web hosting - Easy Filehosting
hi
I cannot get a code for my opcom.I unfortunately upgraded the thing before activation any ideas?
cannot go into the rapidshare link as you only had 10 goes and no more.
I cannot get the winhex suppled by the ebayr to load.
thankyou
Here winhex. You have to use the descriptions of how to use, but you can find the activation code, just need to type the serial and then F3 to manually search the bottom. I found after 1 hour
Thank you for the download.
This does the same thing on two differrent computers.
fails to load and says
c\documentsandsettings\general\localsettings\temp\ bz_temp\winhex154language dat
fails to load
any ideas?
You don`t need install. Only unpack and run winhex.exe. Not registered but by me work
http://opcomforum.yolasite.com/resou...com090821D.rar
unpack and run
rob
Thanks for the reply.This will run but refuses to recognise the interface.
When going to diagnostics it says acannot load the ecu list.
I think I made an error when first loading the soft ware the old software would not load so I tried the after the firmware update.Hexwil will not load or run.When opening the update software the computer finds the interface and the tx light goes on.I cannot get the activation code as hexwin will not load or run.
have I cocked it up?
should also add the opcom version o9082b
and I also forgot winhex will not run either.
Thanks for this
