Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
Thread: DQ381 DTC off
  1. #31
    May 2023
    Default Attachment addition
    Hi, can somebody do a DTC Off for me? Thanks!!!!!! 've been 5 months without my car due this. Can't find the replacement here in my country.
    2013 - Audi Q3 Stronic - DQ500
    Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
    Part No SW: 0BH 300 011 T HW: 0BH 927 711 C
    Component: DSG DQ500-7A H07 1810
    Revision: 00H07V01 CVN: 6E4DBBEE
    Coding: 0014
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMDQ500021 001001
    ROD: EV_TCMDQ500021_001_VW37.rod
    VCID: 3365AACB9A35611702-8066
    1 Fault Found:
    10753 - Transmission Input Speed Sensor (G182)
    P0715 00 [047] - Circuit Malfunction
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 112950 km
    Date: 2023.01.18
    Time: 01:10:27
    Engine RPM: 1724.00 /min
    Vehicle speed: 0 km/h
    Coolant temperature: -40 ∞C
    Clutch: primary stat: New
    selected gear: GANG N
    Driving position: P
    Engine torque: 80 Nm
    Control Module temperature: 97 ∞C
    Accelerator pedal position: 33.6 %
    DTC memory status: 255
    Last edited by rush1420; 7th August, 2023 at 07:43 PM. Reason: Attachment addition
  2. #32
    May 2017
    why no fix the issue?
  3. #33
    May 2023
    Please, if anybody can help I will be grateful for life.
  4. #34
    May 2023
    Can't find the replacement here in my country. I also bought two DQ500 Mechatronics and was scammed, both of them with faults. So, I want to make a DTC-Off and wait until I travel outside the country to buy a new mechatronic unit one. Car is working ok, but sometimes it gets in protection mode.
  5. #35
    Basti13's Avatar
    UK
    I need remove fault P0607 someone can help ? Skoda 2018 Vag fault code is 10925
    NO PASS
  6. #36
    Nov 2021
    test this file
  7. The Following 2 Users Say Thank You to Nick24 For This Useful Post:
    Basti13 (21st November, 2023), Robon (21st May, 2024)
  8. #37
    Oct 2016
    hello all need help need a DTC P0C2900 off for DQ381? Thank you all
  9. #38
    Jul 2014
    Hi to All
    Can anybody help with dtc off
    P0717
    Vl381
    Thanks for advance
  10. #39
    Hallo next one, can someone help with DTC off P0607-00 (VAG 10926), pls
    WBR Rob
  11. #40
    Jan 2018
    ROMANIA - SATU MARE
    Default DQ381 DTC OFF PLEASE
    Hi. i have a trouble code that i would like to be removed please if you can help me.
    Thank you
