pass please THX
pass please THX
Hello
I have the same problem. Same ecu's same problem. The 233 one is fitted to engine with CR CP1 pump where fuel regulator is normally closed, the other ones CR CP3 fuel regulator is normally open. I couldnt find any parameter to change to CP1 pump strategy in pps or lexia either. Prapobly I will have to change cr pump. Ps if you find any solution please let me know im under big preassure :P
please pass
Hi, please pass
but is it possible?
just read 2 posts to find passwords
edc16 checksum
Pass please !!!
Dear benci1982 & Friends.
I have been looking at the calculation formula and my head is hurting trying to work out how the formula is applied, the images below are from two files here which has had the check sum corrected by benci1982.
Does it work I'm guess it does.. ?
Q1 = Am I right that this is a used ecu to be fitted to the car ? I guess yes..
Q2 = The login has not been changed only a check sum change ? I guess yes..
I'm like a dog with a bone over this Please help me apply this formula before my brain explodes
Darwins
PS: I understand if this is PM to me....
Thank you benci1982 for the help
Go for it. The future is promised to no one
can i have the pass
EDC16 checksum don t work
thank you
Thanks for the password.
"I find your lack of faith disturbing"
If you found my post useful, please use the "Thanks" and "Rep" buttons.
Hello All,
I have a 2009 Peugeot boxer 3.0 which is same platform as Fiat ducato. ECU is 0 281 014 211 and it is currently blocked. Vehicle won't start. I need to recode pin number.
I have pin number: 44556
Just some questions:
a) Does your algorithm supports 5 digit pin code such as mine? If not, what am I supposed to do? runing out of answers...
b) If so, I guess same method is used to get info on the 5th digit.
c) In the formula, where do you get the first codes to XOR with the pin to obtain the code? example "FABE8675" XOR 4A514835 (where does the FABE8675 come from) for each line.
d) Same as above for check sum FD 4D=FFFA-2AD (where does the FFFA come from)
e) Are those codes the same for all ECU's?
Thanks for your help.
AIDIN R O (24th January, 2024)
