    Oct 2008
    Harrow
    Default is there a guide which shows me how to FTP CAMS manually?
    Hi, there, ive run a search on your forum for an answer to my different and a bit more specific question which is as follows:
    I have a dreambox 5620s its a DVB-S receiver as opposed to many memberswho have DVB-C receivers.
    The DB has been flashed with a fairly recent gemini image and i know that it is possible to install many cams via the remote control.
    However i wish to install the GBox cam, but i do not know how to FTP to my dreambox, as ive never needed to do it before.
    Is there a guide available, or can another member please provide me with detailed instructions as to how i can FTP the Gbox cam from my laptop to my dreambox?
    my laptop is old so it has the correct connection for a null modem cable
    i have a null modem cable and the dreambox is currently connected via ethernet to my router. i also have the Total commander and the FTP commander programs- but dont know how to use either program.
    As i stated my situation is different to other members who used dreamboxes which were DVB-C and needed to input things such as keylists (that doesnt apply to me as my receiver is a DVB-S receiver)
    thank you
    V.I.P. Member westkill's Avatar
    May 2008
    have you got a ethernet cable from your router to the dreambox or a cross over cable from your pc to the dreambox
    download dcc once programe setup add the ip of your pc and setup the ip on the dreambox in menu>setup
    then try connect dcc
    Digital Kaos - Downloads - Dreambox Control Center
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    May 2008
    or try flash fxp ftp programe which is in the downloads
    and theres a guide in the cable section
    Oct 2008
    Harrow
    sorry man i should have been a bit clearer theres an ethernet cable running from the router to the dreambox
    i connect the laptop via a separate ethernet port on the router connected to my laptop via ethernet wire
    i thought that DCC is only used to edit your channels lists- bit like a favourite channel arranging prog
    i also thought flash fxp is only used to flash images
    ive read the guide in the cable section mate but that only shows you how to flash images onto a cable box mate, and im trying to flash a cam onto a sat box- havent done it before- 1st time for me
    May 2008
    dcc does ftp,telnet,settings, etc
    ftp is used to add key files ,cam addons
    May 2008
    when ftp is setup on dcc
    ftp the file from your pc to the temp folder then go to addon manger then manual install
