hi
2014 should be old type passat with immo in Comfort module nothing in dash except KM
so read CCM 95320 behind glovebox prepair key with ID46 and programme
regards
So several years ago I used to use zedfull for immo 4 clusters with great success, but sold the tool.
Then I got spoiled with online calculation, but that is done now.
So I bought a boot pin cluster cable (the supervag one, svg149), and was hoping to combine this with im608 (basically boot cluster into service mode where just brake light is on, and then come in with im608 to read immo and make dealer key)
However, I was able to get cluster booted, but im608 didnt work for this method (at least on this cluster)
So I ordered vvdi key tool plus, and it will read vin and autodetect cluster but says it is not supported, so I have no luck reading eeprom or immodata, but I can do immoscan.
Cluster type according to keytool plus:
VAG PART #: 561920970G
HW / SW: H04 0811
INSTRUMENT #: C64
NEC+24C32H04 0811
Is this just a cluster these tools dont support or am I doing something wrong? I tried nec+24c32 and several others to no success.
Thanks in advance!
P.S. Car is keyless
hi
regards
Passat stores Immo in CCM, after 2015 usually it's MQB platform and stores Immo in cluster, but in this case it's not an Immo4 cluster where you can put Eeprom in service mode like older ones.
ECU-IMMO-Dash-Airbag Solutions
VAG Immo Transfer Solutions
FRF/SGO/ODX/SOX <--> BIN Conversion
Antonio266 (8th April, 2022)
Because this cluster was configured for Kessy it doesn't allow you to get access, even though a valid key is in range.
Simple solution would have been to temporarily disable Kessy in coding (in 25-immo).
Andreastech81 (16th May, 2022), Dunker (24th May, 2022)
