This is a simple program written in Java which allows you to automatically generate a .swkV3 and install the infinitelease.dat file (this last file is not generated by the program but copied since it is universal and not generated depending on the hardware. I do not intend to take credit for the discovery/generation of this file).
The software should work with any version of GDS but do not take this for granted. WARNING! Keep in mind that this program could fail in any moment and if you want to use I am not responsible for any drawbacks it might have on your system.
I decided to include java directly inside the archive in order to enable the program to run without the need to install Java, although you can delete "jre" folder as well if you do have installed Java already.
History:
V1.0.2: launch version
New Links:
https://mega.nz/file/t2hj1KKT#ZJInmB...27NSyvQaYfPiAk
