null modem cable like 2====3 3====2 5=====5
Hello Chetan,
I bought six months ago that the SBB in China, and had the version (SW) 24.00.112-version (DB) 26.00.
The SBB brings an update CD, I upgraded to this CD, with the bad luck that I update
online, after updating, the SBB was as if out of tokens, could make everything, except
the PIN CODE which was disabled. I was lucky and not go blank, as I happened to some
you.
Because of this situation, I countershaft SBB CHINA again, and they would update the SBB with the update:
version (SW): 25.00.114
version (DB): 28.00
Updates. : 01/2009
that they believe is the latest update.
The version that is inside. Rar whom you have sent is:
version (SW): 24.00.112
version (DB): 26.00 which is the version that I had when I bought the machine in China.
so you can see I attached two sacks.
I take this opportunity to ask if in some future update, you can schedule
Ford Patch 5 system, which calls outcode / inCode.
thanks for your help
Best regards
Well, after the update my SBB stopped working.
Only a blank backlit screen after the power cable is plugged in.
Est Modus in Rebus !!!
What kind of mistake could I have ever made?
It updated OK, I disconnected it from the PC, turned it on, it worked, turned it off, then back on and no more SBB.
I can't update my SBB because none of my computers have a 9 pin RS232 port. Would a USB to RS232 cable work?
D.
Of course it would, that's what I was using.
Good luck with the firmware update though ...
Hello everyone can someone solve a probblema, I have a vore sbb updated but when I connect my computer to see photos from this probblema thanks to all ...
Hola todos ...
When you connect it alone, what do you see on the screen after boot up?
schema see this ...
version (DB): 28.00
Updates. : 01/2009
I did not connect with the computer sbb, rs232 port gives me error, see attached
I saw it hombre.
I just wanted to make sure it boots up.
As for the problem you have I can not help you unfortunately.
Sorry, good luck.
Hi there Todos .
Try different RS232 settings ie Baud rate i.e 9600 etc com 1 ,2 etc .
Also make sure lead is correct .
Hop ethis helps .
P.S dont check for update online it will get zapped it you upload to it from Silca if its a China Clone?.
hello, recoder thank you for your reply, I tried to change the baud rate, com port 1,2,3,4, but no way the answer is always the same, sbb is a Chinese clone
Todos, do you use a USB or a serial port on your computer to connect the SBB?
