Results 1 to 15 of 16
    Feb 2022
    Silesia in Poland
    Default Ford EDC17C10 please verify eeprom
    Hello.
    I'm new to the forum and just starting my adventure.
    My patient is Ford Fiesta 1.6 2010. The engine stopped starting.
    The errors I had were: P2508, P0606, P060B.
    I replaced the ECU, the same numbers as AV21-12A650-HG, 0 281 017 828.
    I read the eeprom and maps of the old ECU and uploaded to the new one.
    The car still does not start. Maybe my eeprom is broken? Can someone verify it? Maybe I should also post a map?
    Or has any ideas what to do next?
    Thank you very much.
    introcrack's Avatar
    May 2020
    Tunisia
    Quote Originally Posted by fisz8809 View Post
    Hello.
    size of this file is incorrect
    Write This on eeprom and micro(mpc)
    Pass on PM
    Dont forget Thanks and rep
  3. The Following User Says Thank You to introcrack For This Useful Post:
    fisz8809 (15th April, 2022)
    Feb 2022
    Silesia in Poland
    Thanks for the uploaded files. As soon as I load them, I will let you know if they work.
    So in the future, what program are you able to validate the file or edit?
    I am new and I would like to learn as much as possible, not just get rid of the problem as soon as possible.
    introcrack's Avatar
    May 2020
    Tunisia
    This is a file viewer and comparer
    contact me on insta or fb if you need some help or tutoriol
    check PM
    Feb 2022
    Silesia in Poland
    Are these files really for Ford? k-t recognized the PSA plugin. Please confirm.
    introcrack's Avatar
    May 2020
    Tunisia
    yes it is
    it is the ame reference for ford and PSA
    Feb 2022
    Silesia in Poland
    Unfortunately, the engine does not start. Additionally, the led from immo is flashing.
    Any more ideas?
    introcrack's Avatar
    May 2020
    Tunisia
    send micro reference like TC17xx
  10. #9
    Feb 2022
    Silesia in Poland
    Tu są moje oryginalne pliki. Procesor to TC1797.
    Ford.zip
  11. #10
    introcrack's Avatar
    May 2020
    Tunisia
    Ford.zip
    write this on eeprom 100% work
    Password the same old
  12. The Following User Says Thank You to introcrack For This Useful Post:
    fisz8809 (18th April, 2022)
  13. #11
    Feb 2022
    Silesia in Poland
    I tried, but my car is too fickle. I still don't want to take off. I noticed that my eeprom must have vin number and mileage (probably also immo) to start.
    I tried this combination (I have two ECUs):
    In the new one I left his mcp, but I loaded the eeprom from the old one (where is the immo and vin preset).
    Effect: The immo light goes out, the car sneezes once every 5s when it wants to start, but it doesn't work continuously.
    Could you please change my eeprom from the new ecu to include information from the old one?
    I am attaching a file.
    New.rar
  14. #12
    Ecuprog31's Avatar
    Mar 2018
    You can rewrite original file from used ecu and adapt it by obd with forscan
  15. The Following User Says Thank You to Ecuprog31 For This Useful Post:
  16. #13
    Jul 2018
    return back working dump into ECU, contact me - I will help you to adapt this ECU to car via dealer online.
  17. #14
    Feb 2022
    Silesia in Poland
    It would be great. Do I need more than the forscan and ELM327?
  18. #15
    Jul 2018
    need J2534 interface
