Results 1 to 12 of 12
    credoline's Avatar
    Србија
    Default Ducato 250 engine F1AE3481D
    Hi friends, anyone have engine ecu schematic diagram for Fiat Ducato 2.3 JTD year 2014 typ 250 engine F1AE3481D with Marelli fuel injection 8F3 ? I need EGR 5 pins where are connected to pins of engine ecu. Because i have DTC that i EGR open circuit. New EGR was mounted.
    Thank you
    Prichyndel's Avatar
    May 2012
    UK
    Here you have,not exactly for F1AE3481D but egr should be the same. check if wire colours are the same.
    Br.
  3. The Following User Says Thank You to Prichyndel For This Useful Post:
    credoline (25th April, 2022)
    May 2024
    I have the same issue. I have the schematics for the "F1CE0481D" and the "FIAE0481D". The "3" changes in the code. And the actual layout of the harness differs too.
    May 2024
    Quote Originally Posted by JuanGali View Post
    Is there a way for me to access the .rar?
    credoline's Avatar
    Србија
    I have 3 different schematic diagram, depend of fuel injection:
    1. Ducato 250 2.3 JTD EDC16C39
    2. Ducato 250 2.3 JTD MJD 8F3.xx
    3. Ducato 250 3.0 JTD EDC 17CP52
    What you need ?
  7. The Following User Says Thank You to credoline For This Useful Post:
    JuanGali (14th May, 2024)
  8. #6
    May 2024
    Quote Originally Posted by credoline View Post
    What you need ?
    Hey Credoline.
    The DUCATO I have is a 2.3 JTD, so, please, the first 2 (EDC16C39 AND MJD 8F3.XX). I have a X250 Elearn manual, but it doesnt support the F1A3481D motor model. Maybe your schemas are different. Fingers crossed, and much obliged.
    Cheers.
  9. #7
    May 2024
    I found this bit of info. Its all in Spanish, but it relates to the motor model in question. The whole schematic would be great though.
  10. #8
    credoline's Avatar
    Србија
    It is so hard to check what fuel injection you have ?
  11. #9
    May 2024
    Its a X250 2.3 JTD 130HP/CV motor. Common Rail injection type, like most of these motors. What changes from other models is the ECU, which is why I'm asking for anything you have. I checked the one installed on my Ducato and its a MJD.8F3.
  12. #10
    DK Veteran kasim_izmir's Avatar
    turkey / izmir
    hi , here is egr schema
    egr pin 2 - 12 volt igniiton swith
    egr pin 1 - 5 volt
    egr pin 3 - gnd
  13. #11
    credoline's Avatar
    Србија
    Here is it, what i have.
    Y151 is egr valve.
  14. The Following User Says Thank You to credoline For This Useful Post:
    JuanGali (29th May, 2024)
  15. #12
    May 2024
    I bought the entire thing in Italian. Shame i cant upload it.
