Results 1 to 5 of 5
    Jul 2020
    Default Mercedes EDC17CP46 DPF EGR ADBLUE ORI FILE
    So I am coming with an issue, a frien of mine came to me with his sprinter, claims someone deleted adblue dpf and egr , no issues with adblu, EGR dtc came on today on Xentry diag , the problem is the DPF . Car goes into regen because of distance done so after 800KM it request regen and tries to regen . Car has very hight fuel consumption and lack of power . I need ORI file if someone has it or DPF solution on this file . Ash accumulation is at 3-4% but still goes to regen by distance .
    maybe someone had this issue before . I tried to do it with vediamo wich is the best way but I think I don't have the right CBF file, every seed key I calculate is failing .
    Jul 2020
    No one able to help ?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    This solution is not right
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Jul 2020
    Quote Originally Posted by Ignasvw View Post
    Can you help ? with the right solution ?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Here it is
  6. The Following User Says Thank You to Ignasvw For This Useful Post:
    costyrzv (21st April, 2022)
