1. The obvious would be to, shutdown computer and restart, then try deleting it again.
2. Make sure the file download is completed, if not kill the download and try to delete.
3. Check task manager to make sure file not in use.
the movie download is complete and plays. restarting makes no difference.when i press delete a popup box appears and says-preparing to recycle and underneath that it says-from discovering items and a coloured bar moves across the box constatntly for hours on end. i tried to google the problem but cant find an answer that works.
this soultion worked for me
right-click on the file, select Properties, then under the General tab select the Advanced button for Attributes, then uncheck both options under the File Attributes section ('File is ready for archiving' and 'Allow this file to have contents indexed in addition to file properties'). After applying these changes, the file can be instantly deleted.
when i right click then click properties nothing at all happens. i am going to try the msconfig way now.i will let you know.
no joy. i rebooted in safe mode and deleted it to recyle bin now i cant empty recycle bin!
success. rebooted again in safe mode and emptied the recycle bin and it appears to have worked..thanks for your help
Glad it worked out for you.
If you have this trouble again there are several utilities available for deleting locked or in use files but I dont have win7 so dont know if they are compatable,
Google for
File Assassin
Move on Boot
Unlocker
Hope this helps for future reference
I believe also that in Win7 some file installs and deletes depend on the users permissions but I am not sure about this.
very good post and much informative
install this software then right click on the file you wanted to delete then select unlocker and then unlock all processes using that file then delete the file
Unlocker - Free software downloads and software reviews - CNET Download.com
how was the mkv downloaded? from the net or via a torrent utility?
