it doesn't work with flash you can buy a virgin ecu
Try this and post result.
send me the login (pin code) of the car
you can not make im*o off in this car .
you will need to rest the ecu then program it to the car again .
God does not play dice with the universe . (Einstein)
if anything can go wrong it will . (Morphy laws)
yes, it possible im*o off or virgin
yes , you can not disable the im*o but you can reset the ecu so the ecu can except the new car code first time the ecu will run on the car .
if you have the original ecu and its dump is still ok then you just need to copy the dump from the old one to new one and you are done .
in case the old ecu has a corrupted dump so we will need to make a new dump that contain the original pin code for the car .
Good luck
Kanaan
Sorry for the lack of news. I have managed to make immo off with immocleaner2. But the engine didn't start. So I asked a very nice girl to borrow her 307 for 2 hours, and I cloned the BSI, ECU, teached a new key ( ID46 ) and vrooom.
Thank you all for your help.
