Results 1 to 13 of 13
Threaded View
    Aug 2019
    Czechia
    Default BOSCH EDC16C8 pls help
    I did read ECU with KESS (multiple times, after I tried cheap cable from China, with same result)
    After recieving ECU SW I got error with winols (some broken part) and also with kess v2 (RSA error)
    Would be the ECU EEPROM broken or is only written map broken? I was afraid to load original file, because of error and car is owned by friend, so there is no possibility to experimentation.
    file in the attachment.
    Thank you guys, every answer is REP+ and thanked automatically
