Results 1 to 9 of 9
    Jan 2018
    Default Rail pressure map decode
    Hello, please advice how to decode rail pressure map. It is vw 1.6 tdi, ecu PCR2.1. Max pressure of this system is 1800 bar. There is max. value 26214 in chart.3.JPG
    Thank you
    gomku's Avatar
    May 2017
    pcr2.1 rp factor : 0,006104
  3. The Following 3 Users Say Thank You to gomku For This Useful Post:
    nbtechnic (15th May, 2022), Radekuno (15th May, 2022), vnkto (17th May, 2022)
    Jan 2018
    Quote Originally Posted by gomku View Post
    Thank you very much! And, is this factor same for all maps? Or another maps (for example turbo pressure) have different factor?
    gomku's Avatar
    May 2017
    Of course! most of them have different factors
  6. The Following User Says Thank You to gomku For This Useful Post:
    nbtechnic's Avatar
    Jan 2016
    Indeed, depending on the software used, the figures will be presented differently.
  8. #6
    Jan 2018
  9. #7
    Jan 2020
    Bulgaria
    XAXAXAXAXAXA ~~~~ing Siemens. I did not know this factor. I learned something useful from this post. Thanks on #gomku
  10. #8
    May 2017
    in ori max pressure pcr2.1 is 1600bar
  11. #9
    nbtechnic's Avatar
    Jan 2016
    Default additional map to find
    Quote Originally Posted by Radekuno View Post
    Do you know any more factors of these maps?
    Hello, check which map you are missing from the list below
    EGR map
    DPF map (from year 2008)
    DriversWish map
    Torque Limiter map
    Smoke IQ Limiters map
    Boost map
    Boost Limiter map
    N75 map
    SVBL map
    Duration map / Explain of Duration Map
    Start Of Injection (SOI) map / Explain of SOI map
    Torque To IQ map
    Lambda Maps
    Rail Inject map
    SVRL map
    a thank you and a rep is appreciated if i helped you
