Results 1 to 7 of 7
    Mar 2021
    Default W639 Vito, change VIN in EZS using DAS?
    I have a 2004 Mercedes Vito.
    It looks like the EZS was replaced at some point and the VIN in it is different to the other modules on the van, it gives some errors like SRS.
    I need to change the VIN but it's not working via the developer mode coding in DAS, I have a C3 with 2014 DAS standalone.
    How can I fix this? Offline SCN? Or some other tool.
    Thanks.
    workshop
    you need other tool,disable vin check on airbag with dev.
    Mar 2021
    Hi thanks for the reply, what is the option called in developer? I looked but couldn't see one but my German is not too good.
    Is there a tool that's reasonably priced for EZS? I'm just doing my own van so don't want to pay thousands. Can I read with orange 5?
    workshop
    yes orange hc908 ok,you can read and vin change vin inside chip r1
    Mar 2021
    I found the option to turn off vin checking in developer, it's called FIN rather than VIN in the German coding options.
    For the first time my van has no warning lights.
    Thanks for your help.
    May 2022
    Ukraine
    VIN in Airbag ?
    Mar 2021
    Quote Originally Posted by Sikim View Post
    VIN in Airbag ?
    Yes I turned off VIN checking in airbag. EZS VIN is different to airbag/SRS and this gives an error on the dash, I can't change the VIN in the EZS without SCN coding or eeprom tools but I can tell the SRS not to check the VIN in developer mode in Star/DAS.
