Results 1 to 9 of 9
    Apr 2009
    Default Mercedes 205 2017 ADBLUE and SCR remove needed
    Hello
    Can someone turn off ADBLUE and SCR on this flash?
    Mercedes EDC17C66 Bosch
    thank you
    May 2022
    AdBlue and SCR is the same system
    Yes, possible to disable completely.
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    after write file, disconnect adblue module
    pass on p.m after rep + thnx
  4. The Following User Says Thank You to exxl For This Useful Post:
    simplextibi (17th May, 2022)
    Dec 2018
    Quote Originally Posted by simplextibi View Post
    Hello
    thank you
    try this good solution
    https://www.digital-kaos.co.uk/forum...64#post4342164
    Apr 2009
    Thanks this flash worked ok
    Did you remove Adblue and Nox not just DTC?
    Apr 2009
    Quote Originally Posted by exxl View Post
    All works ok
    Thank you for the fast and good work
    exxl's Avatar
    Jun 2009
    its a complete solution, glad i could help.
    b.r
    Apr 2009
    unfortunatly after like 3 starts flash deleted itself. Maybe a checksum problem
    could you correct it please?
  10. #9
    exxl's Avatar
    Jun 2009
    here with chkm ok pass is same
