Results 1 to 8 of 8
    Mar 2018
    UK
    Default BMW CAFD coding problem
    I played to replace the VIN on test FEM and lost the CAFD coding
    I had this before and usually no problem to recover but now no success - I use CGDI and always ending with OBD time out
    Ive tried new programming new coding but always finish with time out when try to program CAFD - no problem to update other files
    also I wrote back the original eeprom and unlocked the FEM again and tried again no success
    I checked on other FEM no problem to program CAFD
    any ideas?
    have you tried coding with another tool (e-sys, icom, autohex) ?
  3. The Following 2 Users Say Thank You to u.s For This Useful Post:
    Manta1600 (20th May, 2022), qwojtus (20th May, 2022)
    Possible someone has changed the FA in the past and VIN coding is not acepted.
    Auto hex, CGDI, Autel or something else must do it but
    the best to flash with esys and it verify any software errors.
  5. The Following User Says Thank You to qwojtus For This Useful Post:
  6. #4
    Mar 2018
    UK
    Quote Originally Posted by qwojtus View Post
    I have Autohex but not full so can't do programming
    Autel can't do it I tried on other car few months ago and sorted with CGDI after that
    I have Esys but is not configured properly on the my laptop and at the moment is useless
    alex_r_2001's Avatar
    New Jersey ,, USA
    E-sys is best for me once you get used to using it.. I have Autohex full and I still prefer to use e-sys most of the time.
  8. The Following User Says Thank You to alex_r_2001 For This Useful Post:
    Manta1600 (21st May, 2022)
  9. #6
    To use coding in Autohex dont need to have full version.
  10. #7
    Mar 2018
    UK
    with light locksmith version is not possible
  11. #8
    Oct 2018
    egypt
    Must install and Try esys ... also flash to latest swfls with coding ... sure will work if fa is correct ...
    wbr.
  12. The Following User Says Thank You to hesham10 For This Useful Post:
    Manta1600 (22nd May, 2022)
