DTC P1436 disabled! found 1 time(s) -
DTC P1437 disabled! found 1 time(s) -
DTC P2028 disabled! found 1 time(s) - Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit Intermittent
DTC P2032 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 2
DTC P2033 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 2
DTC P2034 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 2
DTC P2036 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit High Bank 2 Sensor 2
DTC P2069 disabled! found 1 time(s) - Fuel Level Sensor "B" Circuit Intermittent
DTC P2078 disabled! found 1 time(s) - Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit High
DTC P2079 disabled! found 1 time(s) - Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Intermittent
DTC P2081 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 1
DTC P2082 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 1
DTC P2083 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 2 Sensor 1
DTC P2085 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 2
DTC P2086 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 2
DTC P2087 disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 2 Sensor 2
DTC P2359 disabled! found 1 time(s) -
DTC P2610 disabled! found 1 time(s) - ECM/PCM Internal Engine Off Timer Performance
DTC P2621 disabled! found 1 time(s) - Throttle Position Output Circuit Low
DTC P2626 disabled! found 1 time(s) - O2=Sensor Pumping Current Trim Circuit/Open Bank 1 Sensor 1
- DPF/FAP deactivated with success
