Results 1 to 13 of 13
    dehacko's Avatar
    Feb 2018
    SK
    Default edc17c46 after read flash ECU not work
    hello please help my I need full back for ktag sw 03l907309ae manual trans. hw: H28 0281017946
    after read flash ecu not work. (read with ktm flash)
    ecu in the car not comunication, k-tag bench no idetifing ecu
    any idea?
    rafal's Avatar
    UK - PL
    probably not reading problem - but after opened.............
    need help
    now my goal is to buy xp-005
    who will help?
    Jul 2018
    ktm flash is a bad clone of pcm flash. many ecu killed by ktm. only try boot , not bench.
    my advice is open ecu, 1. read with ktag in boot mode, repair file and write
    2. if reading is imposible...here is a link with all flash files for edc17c46 pack for PCM flash...try ur luck
  4. The Following 2 Users Say Thank You to Aladinnu For This Useful Post:
    dehacko (1st June, 2022), nbtechnic (1st June, 2022)
    dehacko's Avatar
    Feb 2018
    SK
    I know where the problem, my mistake.
    I connected the cables incorrectly.
    I buy new ecu and did immo off, car start well but immo light on. I dont know how to make long coding and immo off without immo shows on display
    Any idea?
    dehacko's Avatar
    Feb 2018
    SK
    Aladinnu thank you
    Ktag boot mode not work, ecu is damage, i buy new ecu but after immo off cluster show immo and car run
    Jul 2018
    Problem is clone tool, ur immo off solution not ok if showing dtc
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    When you are able to read "old" ecu flash+eep...then is better to clone immo data to "new" ecu and everything will work like nothing ever happend.
    Jul 2018
    Quote Originally Posted by Junkyard Dog View Post
    Not all ecu can be cloned. Some have OTP
  10. #9
    dehacko's Avatar
    Feb 2018
    SK
    Thank you all for answers
    All is done... New ecu flash with pcm flash genuine, Immo adapting with arbitres genuine and long coding, clear all adaptations with vcds clone. All work well
  11. #10
    jurebv's Avatar
    Dec 2017
    Croatia
    even ecus with OTP can be cloned, just not by "reading old / writing to new" method
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  12. #11
    Jul 2018
    Quote Originally Posted by jurebv View Post
    Yes but with good tools, no way with clones, in his case we talk about ktm bench
  13. #12
    jurebv's Avatar
    Dec 2017
    Croatia
    its possible to clone even with ktm bench if you know how to
  14. The Following User Says Thank You to jurebv For This Useful Post:
    mprog (3rd June, 2022)
  15. #13
    mprog's Avatar
    Feb 2017
    Europe
    Exactly no tools but brain is the power
    Best Regards
    File Service - contact PM
    "Naród wspaniały, tylko ludzie ku*wy" - Józef Piłsudski
