hello please help my I need full back for ktag sw 03l907309ae manual trans. hw: H28 0281017946
after read flash ecu not work. (read with ktm flash)
ecu in the car not comunication, k-tag bench no idetifing ecu
any idea?
any idea?
probably not reading problem - but after opened.............
need help
now my goal is to buy xp-005
who will help?
ktm flash is a bad clone of pcm flash. many ecu killed by ktm. only try boot , not bench.
my advice is open ecu, 1. read with ktag in boot mode, repair file and write
2. if reading is imposible...here is a link with all flash files for edc17c46 pack for PCM flash...try ur luck
I know where the problem, my mistake.
I connected the cables incorrectly.
I buy new ecu and did immo off, car start well but immo light on. I dont know how to make long coding and immo off without immo shows on display
Any idea?
Aladinnu thank you
Ktag boot mode not work, ecu is damage, i buy new ecu but after immo off cluster show immo and car run
Problem is clone tool, ur immo off solution not ok if showing dtc
When you are able to read "old" ecu flash+eep...then is better to clone immo data to "new" ecu and everything will work like nothing ever happend.
even ecus with OTP can be cloned, just not by "reading old / writing to new" method
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
Thank you all for answers
All is done... New ecu flash with pcm flash genuine, Immo adapting with arbitres genuine and long coding, clear all adaptations with vcds clone. All work well![]()
its possible to clone even with ktm bench if you know how to
mprog (3rd June, 2022)
