Results 1 to 15 of 19
    DK Veteran strda50es's Avatar
    Belgrade
    Default Smart for two (451) tuning hardware?
    Hi all.
    Would like to know if someone could suggest me a semi pro or pro tuning tool for the new range (wme451) of smart cars.Any suggestion would be much appreciated.Thank you all in advance.
    FGTech Galetto EOBD Master tested, diesel engines, works good
    Quote Originally Posted by bynow3 View Post
    YES READ GOOD
    PUT RITE BUDD:-((((
    Top Poster physyc's Avatar
    May 2012
    No prob for writing....
    Heaven is where the police are British, the cooks are French, the mechanics are German, the lovers are Italian and it is all organised by the Swiss.
    Hell is where the police are German, the cooks are English, the mechanics are French, the lovers are Swiss, and it is all organised by the Italians
    read only boot mode?
    DK Veteran wsc's Avatar
    GR
    and write also boot mode
    Smart car engineer ,
    AVDI ,WRITE right in petrol engine. Not tested in diesel
    regards
    galetto 2 no need boot mode, as I remember... Neither for read nor for write...
    are you sure? can someone confirm this
    May 2012
    why you need confirmation?
    Plug it in try it. if not ok need boot mode.
    No black magic, no rocket science...
    Quote Originally Posted by physyc View Post
    i don't have interface
    but in car list for galletto2
    Smart 600/700 0.6/0.7l Bosch MEG 1.1 R/W -- BootMode+Flasher
    wiseman's Avatar
    Read requires boot mode, writing doesn't. Galletto also reads EEPROM
  13. #13
    Jan 2011
    Hi,which Kind of ecu has a smart model end of 2007 with gasoline Turbo 84 PS?Is it possible to clone the ecu? Or make immo off? Tuning file???Best regards
  14. #14
    Nov 2012
    smartville in front of a OBDplug
    Quote Originally Posted by TheBadFrog View Post
    it's ME 7.7.0 yes i can clone
    changes 71 Hp mhd to 98 brabus
    no you can't flash over obd protocols are kline and kline is not wired on the car
    Stardiag do it over CAN H /L
  15. #15
    Dec 2010
    Quote Originally Posted by kennfeld View Post
    That is nonsense.
    The 61/71hp is a normally aspirated car, the 98 Brabus is a turbo engine!
    greetings,
    filecloud
