please i need long coding
mk60ec1
1k0907379ce
vin
WVWZZZ13Z9V021934
LHD
1.4TSI
mk60ec1
1k0907379ce
vin
WVWZZZ13Z9V021934
LHD
1.4TSI
I don't understand why you write? Isn't it possible to press a button on a computer? you will see how many bytes encoding, type of suspension, transmission. I do not need the size of the engine, I need its power. And it is important when all-wheel drive and even TPMS. If you want to write, then write everything.
1k0907379ce is not a block number, it is its software.....((((((
Okay, I'll do it with such scarce data.
gonzaaa (2nd June, 2022)
Пробуем HW: 1K0907379 AE
000000000000000000000000000000000000
743B60F50000000000000000000000000000
743B60F5092400FB00000000000000000000
743B60F5092400FB2E1406E7901D00000000
743B60F5092400FB2E1406E7901D00413100
Sorry this is a first time that i need coding. I dont know what is need. Спасибі
I will try to explain everything with an example. There are various nuances of code loss, I cannot know if the block was changed or why it happened. A general scan will make it clear the entire configuration of the car, even its VIN.
Further, there may be problems due to errors, again it is necessary to scan block errors, and not tell on the fingers. And there will be victory
Be sure to learn the words
Слава Украине! You will always be answered and helped
путен хуйло...))))
gonzaaa (4th June, 2022)
