Results 1 to 6 of 6
    Jun 2022
    Default help with software for mercedes
    Hello,
    I found this forum when I was trying to solve my problem with the 7g tronic AT.
    Something is wrong with the gerabox in my car.
    I'd like to check if it has any codes.
    I have a DS150E cdp PRO (2020). I was using opus cars softwere but it can read cars to 2014.
    This mercedes is from 2015.
    Can someone share with me a software which can read my car (which will work on win xp)?
    Of course star diagnosis would be the best but for private use a autocom would also be ok.
    I will appreciate your help!
    Dec 2014
    PL
    Hi.
    To work with the new Autocom / Delphi 2020.23 you need at least WIN OS 7 (32 / 64bit).
    However, to operate the DAS XENTRY PassThru (SD) you need cheap interfaces: Open Port 2.0 * (preferably) or MiniVCI Toyota.
    Preferably WIN OS 8.1 or WIN OS 10 (64 bit) + good processor above 1.5 GHz.
    I checked on WIN OS 7 32 bit 1.4 GHz and DAS XENTRY did not work.(D.X. PT 07.2019)
    fuzz1's Avatar
    Jul 2019
    Buy the cheap obd diagnostic from launch. I think it gives you full access for two cars
    Jun 2022
    To be honest I will probably have to invest a big amount of money to fix the gearbox so I don't want to invest in any new computer and interface right now.
    Can you sahre with me some sowtware which can give me a possibility to check the codes?
    Maybe a previous vesion of auto com/ delphi would work on my windows xp and ds 150e cdp pro?
    Dec 2014
    PL
    Quote Originally Posted by dellx View Post
    The latest Autocom / Delphi will not work on WIN OS XP. You can try Autocom / Delphi 2017.3 C4B. However, in newer cars it does not read measured value blocks very well.
    You have links to SW in this topic. (*Post# 1)
    https://www.digital-kaos.co.uk/forum...hlight=autocom
  6. The Following User Says Thank You to Mario6 For This Useful Post:
    dellx (7th July, 2022)
  7. #6
    Jun 2022
    I guess so. That's why I've asked for something older.
    Thanks for the info. I will try it in the evening.
