Hello,
I'm currently swapping 2.0 tfsi BWA engine in my mk2 golf, donor is '06 mk5 jetta.
I have some issues with throttle pedal, brake and clutch switch, I'm thinking to put a4 b7 throttle pedal instead of pedal from donor, it's easier and looks better in mk2, but I think mk5 pedal is hall effect and audi pedal has potentiometers, how to do to make them work with my ecu. BPP and CPP are the same things, both working with hall effect on cylinders, but audi uses physical switches, and I know they didn't work, tried once on mk5 tsi ccz swap and I had to change the brake master cylinder...
