BMW CAS4 MODULE PROBLEM - LOST CODING
Results 1 to 2 of 2
    Jun 2022
    Default BMW CAS4 MODULE PROBLEM - LOST CODING
    Hi gyus,
    maybe you can help. I was programming 2012 bmw 520d spare key via obd with vvdi key tool plus. Fot got to back up coding. During programming car started active starnge and it stuck. In general tried ones again and then reading key info got message that coding lost. Downloaded D-flash and P-flash files. Found some not extra wiring inside cas4 module not manufactory ones. Looks like P-flash is corrupted as only F letters in it. Cas4 module Continental 61.35-9 268 752.09-01 5WK50523DBR 2112290306. Thanks
    Apr 2014
    Post your dump.
    Sent from my SM-G930F using Tapatalk
