Results 1 to 8 of 8
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Default 26A0700 to PSA Key, transponder OK but remote not work
    Hello friends, i have a new key to Peugeot that i programed for a car but finally it didnīt use.
    Now, i need reset the board and i am trying it changing the mic 26A0700 but when i test it, the transponder works fine but the remote doesnīt run.
    For test, when i go back to weld the original 26A0700, the remote control runs fine but when i weld again the new 26A0700 the remote control doesnīt run.
    I tested two new 26A0700 and i have the same problem with each.
    Do i need program anything to start remote control, please??
    PD: I bought the new 26A0700 in Aliexpress.....
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
    Mar 2018
    UK
    Mate PSA keys cost 5-6USD tell me why you want to replace the chip?
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    Yhoni (5th June, 2022)
    May 2017
    When I program PSA keys Peugeot or Citroen I often have a problem that the transponder passes and the remote does not work. Lately when I need to do PSA keys I first take the universal keydiy key and try the options until I get the remote to work properly. Then I know exactly whether remote ASK or FSK, etc. and according to that knowledge I program the appropriate key (remote). I also programmed the keys from Aliexpress. Maybe this will help you.
  5. The Following User Says Thank You to dragan68 For This Useful Post:
  6. #4
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by Manta1600 View Post
    I know it mate, but i bought 26A0700 time ago for 3€ and i did want to learn how to repair it by replacing it.
    I donīt know if the problem is the new 26A0700, or i need to do it anything after of weld it to that the remote works correctly....
    Do know you it, please?.
    Thanks.
    Yhoni's Avatar
    Jun 2014
    repeated, sorry.
  8. #6
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by dragan68 View Post
    Hello mate, my problem isnīt the frecuency, my problem is that remote control donīt send none signal with new 26A0700, but it woks nice with old 26A0700.
    This is the reason why I have the doubt.
    Is it a problem with the new chip? or, do I have to do some programming to activate the remote control signal sending?
    Thank you.
  9. #7
    May 2017
    On one occasion i bought on aliexpress pcf 7946 blank for some remote key that was locked. I changed the original pcf 7946 with the new pcf 7946. I thought that way I would get a virgin remote key ready for programming on the car. But it doesn't work that way. My friend who has a lot of experience in this business told me that it is first necessary to program the pcf for example with vvdi prog with the appropriate adapter. I have vvdi prog but I don't have pcf adapter. So I gave up on that job. I'm not sure, but it's possible that in your case, too, the mic 26A0700 should be programmed first. Maybe someone who has solved a similar problem should be included in this topic.
  10. The Following User Says Thank You to dragan68 For This Useful Post:
  11. #8
    Apr 2022
    Germany
    I have vvdi prog and PCF adapter...
    The optoin for Peugeot I haven't seen... Only for BMW...
    Please share it if you have...
