Hello friends, Renault service said me this cut key code for Renault Megane: "13113475" but my "mini key tool" say me that is not good.
Does anyone know what numbers are left over in that code, please?
I don't have another key to compare.
Thanks.
Thanks.
If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
I do not answer in private questions that can be solved in public.
what year is the megane ?
renault dealer codes are normally the last 6 digits , reversed for direct cuts .
but to remove chance use the correct lishi tool to confirm
Yhoni (7th June, 2022)
ok its old direct codes so code will be 1st 6 digits , the year of vehicle makes a big difference to how the code is read .
as a 2004 model you forget the last 2 digits and reverse the code for direct key cuts ,
so your code if cutting to code is 131134
if entering direct cuts then your direct cuts are 431131
had you stated the year of vehicle you would have got correct answer first time
though if you used lishi renault v2 tool you would have had the correct key cuts in a minute or 2
the correct cuts are the 2nd picture , bow to left tip to right , 431131
but it depends what machine you use and how you enter the cuts , if cutting to manufacturer code then you enter 131134 the machine knows if its a dealer code to reverse the cuts and cut 431131
if you are entering direct cuts then you enter 431131.
megane , scenic , laguna ph2 cards with dealer code its 1st 6 digits reversed for direct cuts
megane 3 , clio 4 etc its last 6 digits reversed for direct cuts
so when asking for help year of car is important to state
it will be fine if code is correct , if lock changed then you need lishi
