Results 1 to 15 of 20
    Apr 2022
    Default Help Pls EDC17CP14 not starting after writing with ktag
    i have read the backup file but when i try to backup it says wrong backup file... i can write again the ori epr file and micro but car does not start ... i have read and write tricore any help cause u got stuck
    Mar 2013
    Europe
    Have comunication with ECU by OBD?
    Apr 2022
    no there is no comunication with obd ... but i can still write file in tricore ... i am trying to find full backup file for this ecu but i cannot find it so far
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    I´m sure that you talk about chinese red painted something, and you forget to write it down...
    chksum fault it could be...
    but also you damaged soemthing in opening process...
    Jul 2018
    Probably damage while opening. Ktag never fail on these . Try update ecu. Magpro2 x17 can do, autel can do.
    Apr 2022
    the ecu its not broken i can still write ori file the problem is i lost the backup file .. i have only mpc and epr file
    Apr 2022
    the ecu its not broken i can still write ori file the problem is i lost the backup file .. i have only mpc and epr file...............
    carmageddon's Avatar
    Italy
    so if yoou can read/write does that mean is not broken??? if you open the ecu using wrong method you can broke intermediate pcb....then you can read/write successfull but the ecu have hardware KO
    Apr 2021
    ktag dont correct checksum you need correct before writing
    Apr 2022
    finally result ecu is broken ... can anybody tell me ecu list for cloning ,,,,
    Italy
    search used ecu with same HW number bosch 0281xxxxxx, buy it, read e2p only from used ecu and post here with orginal e2p from your broken ecu and wait for someone that can transerf immo data from original to used e2p…write it and be happy
    Apr 2022
    someone said my bosch nr 0281015029 can be clone with this number EDC17CP14-3.4
    0281014236
    0281014262
    0281014390
    0281014396
    0281014397
    0281014614
    0281014615
    0281014616
    0281014685
    0281014686
    0281014687
    0281014688
    0281014692
    0281014693
    0281014694
    0281014698
    0281014699
    0281014700
    0281014701
    0281014702
    0281014703
    0281014707
    0281014708
    0281014884
    0281014886
    0281014887
    0281014984
    0281014985
    0281015004
    0281015005
    0281015006
    0281015007
    0281015008
    0281015009
    0281015010
    0281015011
    0281015012
    0281015013
    0281015019
    0281015020
    0281015021
    0281015022
    0281015029
    0281015191
    0281015192
    0281015193
    0281015194
  13. #13
    Italy
    yes, you must buy 0281015029....you dont need to clone nothing...i wrote above what you need to do
  14. The Following User Says Thank You to carmageddon For This Useful Post:
    selveti2022 (12th June, 2022)
  15. #14
    Apr 2022
    thank you man ..
  16. #15
    Dec 2020
    For Immo Transfer both Eeprom and Flash from the original and donor ECUs are needed, only eeprom is not enough...
    ECU-IMMO-Dash-Airbag Solutions
    VAG Immo Transfer Solutions
    FRF/SGO/ODX/SOX <--> BIN Conversion
