Results 1 to 8 of 8
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default Red Nec Programmer
    Howzit
    Got this red nec uPD 78 programmer keeps on giving receiver timeout error using windows XP pc and com port and cable also tried with Rs232 to usb converter cable same issue
    See my PCB images attached any advice or possible repair option appreciated
    'If I helped, please click Thanks +Reputation.. !'
    May 2015
    My Tool Room
    Howzit
    Anybody can perhaps share images of their PCB just to compare with with what I have on my PC Board
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
  4. The Following User Says Thank You to jomberykaso For This Useful Post:
    rtbdiagnostic (17th June, 2022)
    May 2015
    My Tool Room
    perhaps you can share softare you use for your device i tried on Win 10 get error uPD78 Dashboeard Programmer not found and sometimes receiver timeout error
    How does my PCB compare to yours perhaps any component i can change
    Sep 2013
    Just install the right drivers
    May 2015
    My Tool Room
    my LM7805CV voltage regulator gets very hot when power 12V 1A supply is connected when i remove the Max232CPE driver form the board it goes back to normal operating temparature
    could it be the Maxim 232 driver for the Rs232 port
    SEAT.'s Avatar
    CAPE TOWN
    Hi try this its same as white programmer i used this sw years ago
  9. The Following 3 Users Say Thank You to SEAT. For This Useful Post:
    costa sys (31st January, 2023), Johnner (18th June, 2022), rtbdiagnostic (20th June, 2022)
  10. #8
    May 2015
    My Tool Room
    Where can I buy a good quality NEC uPD 78 programmer tried 2 from both very poor quality with bad quality pcb and components missing
