Results 1 to 5 of 5
    Mar 2017
    RO
    Default PEUGEOT 307 1.6 HDI 2004 additive module location
    Hi there, I make dpf off a Peugeot 1.6 HDI 9HZ engine, and I can't find the location of the additive module to disconnect it.
    On some models the additive module is behind the BSI but on this car it is not there.
    Does anyone have any information on where this module might be?
    The car is from 2004
    Thanks.
    LT & ES
    Check small deposit near fuel deposit
  3. The Following User Says Thank You to olegario For This Useful Post:
    pacurar (19th June, 2022)
    sometimes located under driver seat
    fuzz1's Avatar
    Jul 2019
    You mean the ADblue?
    You disconnect the module and the car will work?
    Mar 2020
    in the field
    It's about the eolys tank. When 4 wires come to the tank, the module is in the tank, when 2 is under the driver's seat
  7. The Following 2 Users Say Thank You to pawl For This Useful Post:
    fuzz1 (22nd June, 2022), pacurar (23rd June, 2022)
