    wiseman's Avatar
    Default X-type jag dash coded to ecu???
    BTW TITLE SHOULD HAVE BEEN S-TYPE NOT X-TYPE \opps
    Got a dash changing job in for jag s-type year 1998. Put the new dash in to check it was working, car wouldnt start. hmmm.......
    X-type , yes definitely. Even the keys are stored in the dash, like VW.
    S-type, i have never done, but if the car is not even cranking, then i would say that is the same.
    Whats inside the dash? Whats wrong with the old one?
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by toniz View Post
    If the dashboard is just physically damaged ... the swap the 912 mcu over ...and it will start....
  4. The Following User Says Thank You to PremierD For This Useful Post:
    wiseman (15th October, 2022)
    wiseman's Avatar
    Quote Originally Posted by PremierD View Post
    The old one just doesnt display anything on the digital display.
    Bought one of ebay was gona change the mileage and pop it in.
    the car was running on the old display fine.
    just swap the 912 mcu Thanks
    I had a similar problem before. It was caused by dry joint on one of the blue smd resistors at the back. I advise you to re-solder all the components on the board and try,
    wiseman's Avatar
    will keep that in mind thank you
