Results 1 to 15 of 15
    Aug 2013
    Default Toyota VIOS and iProg Issue
    Hi, I cannot make iProg read Toyota VIOS 2017 model via DENSO UART, does anybody has a work around or modification done?
    Yes, I am using a cheap China Clone, sorry.
    brend's Avatar
    Oct 2015
    Same where
    What you try read , mcu or external eeprom ?
    Aug 2013
    It is good in reading other dash via mcu or eeprom, just don't work with VIOS.
    I am using the DENSO mode UART.
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by toastedsiopao View Post
    So........ in this VIOS you try read both memory ?
    I think in here external eeprom .
    Why not just desolder for work and that's it ?
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    I always use it without problem,
    Maybe there is something wrong about your connections
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  6. The Following User Says Thank You to hcip For This Useful Post:
    toastedsiopao (20th June, 2022)
    Aug 2013
    Hi is that your own script? Can you share it?
    THanks.
    Sep 2014
    Script presents in iprog clone
    Aug 2013
    Did you connect the 12V from the iprog board or from separate supply?
  10. #9
    Sep 2014
  11. #10
    hcip's Avatar
    Depend on your adapter, My adapter need to connect 12V on Iprog+ hardware
  12. #11
    Jun 2022
    russia
    iprog clone also not work
  13. #12
    hcip's Avatar
    Quote Originally Posted by mackynax View Post
    My Iprog is clone.. serial number 0001
  14. #13
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by hcip View Post
    Your iprog looks very different hcip.
    I bought clone serial number 1 however the soft is not as clean as yours. Mine shows v87. I'll try the other version i guess to see if i get different results
  15. #14
    hivrich's Avatar
    Sep 2012
    Ukraine
    Hello.
    I want to write you a message, but your message box is full.
  16. The Following 2 Users Say Thank You to hivrich For This Useful Post:
    anda2003 (14th July, 2022), hcip (4th July, 2022)
  17. #15
    Mar 2019
    Zimbabwe
    i recently bought iprog clone and i need assistance on how to do in circuit reading of the eeprom lets say 93C56
