Hello to all. Mazda 3 thru obd work ok, kia thru obd work ok, most of older model thru script work ok.
IF I HELPED YOU PRESS THE " T " BUTTON
fuzz1 (22nd June, 2022)
Thank you. What about on bench reading through can and writing via UART with welding adapter line? What's the use of the UART adapter if there is a welding line through the parallel port?
