Help with cuts plz
Citroen C4 2007
I read - CAEACA
Thank you
for me looks like
---A---A---A
-D---B---D--
VA2 card 1049
More like: E A C A E A but it's more like a guessing VA2 from picture.
Vernier caliper and you dont need ask for help each time any more.
Cut a VA2 blade as ABCDEF, then you can compare when use vernier caliper.
Manta1600 (25th June, 2022)
Use micrometer and you cant be wrong.
6841707059 576F526B 57416E5453 596F55 526F6B69424152
The key is for a friend I help out from time to time that lives 400 miles from me I help him with simple keys (none remote)
most I can read for him without any problems
These I always struggle with them - Even if the members Manta1600 & P1et have give me the wrong cuts
I really appreciate the trouble and effort they have gone to.
To help me if the 2 cuts are wrong I have lost the cost of 2 key blanks
if correct my friend is happy
Thank you
So what was the correct cut then? I told you it's more like a guessing with VA2 profile. Why your friend can not use caliper, all dimentions are in instacode or like @lion said, just cut a key A-F and you will have depth sizes.
Its 100% cut on my responsibality
---A---A---A
-D---B---D--
With VA2 always have issue, you may have to cut with Renault Clio cut and use as Manta codes you will only lose 1 more blade.
100000000%![]()
P&D (26th June, 2022)
