Results 1 to 11 of 11
    levisdj's Avatar
    Apr 2010
    EcuLand
    Default Golf 7 EDC17C64 eeprom prepare..
    Hi, I need to clone EDC17C64 ecu from VW golf 7 0281019175... attached original and donor eeprom from ecu.
    I tried the Xtool edc17 immo utility but it's not working.Thanks
    Mar 2010
    Italy
    I think that is also necessary flash of original and donor ecu to decode dump
    levisdj's Avatar
    Apr 2010
    EcuLand
    Here, attached .... thanks
    Mar 2010
    Italy
    Here You go:
    Original data:
    VIN: WVWZZZAUZEP516152
    Comp.: BB6BE198408A39
    MAC: 07DAFCAF
    Login: 55585
    ImmoID: No Immo ID
    Type: IMMO 5
    Status: Not Learned
    Donor data:
    VIN: TMBAE6NH5J4551512
    Comp.: 5B2DDF2EF1ED81
    MAC: CD724D23
    Login: 43292
    ImmoID: No Immo ID
    Type: IMMO 5
    Status: Learned
    Attached EEprom for donor ECU with cloned data from Original
  5. The Following User Says Thank You to taythephoenix For This Useful Post:
    levisdj (28th June, 2022)
  6. #5
    levisdj's Avatar
    Apr 2010
    EcuLand
    I see some parts that the old VIN has remained... what did you use to generate this dump ??
  7. #6
    Mar 2010
    Italy
    I've used Tango
  8. #7
    Oct 2017
    99problems
    Quote Originally Posted by levisdj View Post
    Please report if working.
    I have same situation, same Golf 7 edc17c64 with skoda ecu swap.
  9. #8
    levisdj's Avatar
    Apr 2010
    EcuLand
    Please confirm that the uploaded file is immo off ... thanks
  10. #9
    Nov 2021
  11. The Following User Says Thank You to PEVAG For This Useful Post:
  12. #10
    Mar 2010
    Italy
    Can You test these dump?
  13. The Following User Says Thank You to taythephoenix For This Useful Post:
  14. #11
    levisdj's Avatar
    Apr 2010
    EcuLand
    Will update asap
