Results 1 to 9 of 9
    Jan 2009
    Default BMW cas3 and ecu EDC17CP02
    I need ISn for tango to make key, all key lost
    Tnx
    topclef's Avatar
    Mar 2010
    Try it ISN : 07 9E 2A 59 F7 7A B1 1E 9F BE BE 87 3C 11 9F D9
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  3. The Following User Says Thank You to topclef For This Useful Post:
    rokibar (30th June, 2022)
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by ziko View Post
    Tnx
    About ecu dump's.........
    Ecu isn in tricore eeprom , yours ecu dump from externial eeprom and in here nothing for security .
    NB!!! Don't ask in PM old file password , Im not remember.
    Jan 2009
    Ah, ktag can't read external eeprom?
    Is it on other side eeprom?
    Tnx
  6. #5
    brend's Avatar
    Oct 2015
    Same where
    Tnx
    Ecu isn in this case in tricore eeprom .
    Cas 3+ isn is crupto and for correct decruption need : or tricore eeprom , or worked key , or key dump .
    For me only that's away .
    Maybe in here people have another option without all this , who now .............
  7. #6
    topclef's Avatar
    Mar 2010
    Tnx
    this is your ISN from ECU , use it with Tango 07 9E 2A 59 F7 7A B1 1E 9F BE BE 87 3C 11 9F D9
  8. #7
    Jan 2009
    I put isn, will go to test
  9. #8
    topclef's Avatar
    Mar 2010
    when you put wrong ISN in Tango you'll get ( ISN not compatible to the CAS ) , but if Tango accept this ISN it mean its correct
  10. The Following User Says Thank You to topclef For This Useful Post:
    ziko (30th June, 2022)
  11. #9
    Jan 2009
    Tango didn't complain
    Car started ok. Thank you again
  12. The Following User Says Thank You to ziko For This Useful Post:
    topclef (30th June, 2022)
