hi
135 / 5.000
Rezultati prijevoda
I'm not really into that, but I guess, you didn't do the procedure properly, as far as I remember, you need to lock the mcu after writing! I do not know how
regards
Hi everyone, i have here a dash of a 2008 Triumph Street Triple with PIC18F458, i connected it to the pickit2, read and saved the HEX file, changed the KM value, rewrote the program memory and the eeprom ... but now once powered it shows me the completely blank displays.
I tried to rewrite the original dump but nothing ... it always remains empty.
What can I do?
Please I'm going crazy ))))
hi
135 / 5.000
Rezultati prijevoda
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
Fabry73 (4th July, 2022)
Find yourself a new dashboard. I think you are not going to get that one working again.
If i helped you with your problem, please press the Thanks button.
Ask your questions in the forum, no response on private messages.
Bike not start with donor dash due to immo
I have the same problem i change the EEprom hex data and now the lights goes on but no data on the schreen.
I have a Triumph street triple 2007 PIC18F548 uses the pickit3.
What can be broken and is it possible to fix it or change parts from the dash.
Greetz
Fabry73 Where did you change the KM value?
Oke when i buy a new eeprom pic18f458 and write the original data in it then it works?
I can test it , its interesting to know.
Second dash also don't work.
Maybe i do something wrong wiht the pickit3 software.
I read it says successful
I load a hex file
I write it says successful.
I disconnect the dash.
dashradio (17th August, 2022)
Okay maybe , wich important settings i need for the pic18f458. I was thinking it goes automatically when i select the good pic in the list.
Hello, finely worked the pickit3 on the mplab IPE Change the device to 4,5V Voltage and power target in advance-mode and it connect. i make Screenshots from the Information maybe interesting why it not works because in screen 2 i can see differences from a other hex file same bike other kmst there are a lot diffrent settings.
maybe someone know ??
