just soft modded wii! i read that you can play movie files via usb what do i need for this? any help?
thanks v much i assume when u say install these you mean drag them onto sd card and open homebrew
1 more thing do i need to foermat my usb drive to wbfs?
No you dont use wbfs,just format it to fat32 or ntfs.Copy over film to usb stick and open mplayer..WBFS is just for games...
thank you dude!![]()
try this
SMB shares.
First make sure the folder on your PC is shared with the network. It will assign it a default name which you might want to change.
Then..
In the Mplayer CE folder on the SD card there'll be a smb.conf file.
#Max 5 samba shares (review menu.conf to add more samba browsing)
#no ip or no share means samba disabled
#It's important use quotes (") on shares with blank spaces, see example 2
#Samba share1 (smb1:/)
ip1=192.168.0.1
share1=films
user1=
pass1=
#Samba share2 (smb2:/)
ip2=192.168.0.1
share2="My movies"
user2=
pass2=Then it's just a matter of editing the details to match your PC configuration.
Enter your PC Local IP, it'll not likely be 192.168.0.1 but something similar.
Enter your Share Name, noting that separated words must be enclosed with quotes.
Once you reinsert the SD card and launch Mplayer CE it will allow you to connect to the shares.
Cheers CK.
Updated my Wii a couple of weeks back to usb loader (which is superb) and forgot ho to set up CE player. Works a treat.
Brilliant thankyou, works perfect, did take a little while setting up the sharing as I'm running windows 7 with a cisco network manager but got there in the end.
